cycojon
addicted to my superjet
- riverside ca
hopefully this one won't turn into a debate between after market and OEM what i am looking for is info for witch ones to use!
i see lots of guys useing the single carb F/A on a dual carb setup, are you guys all running dual 44's?
I have stock dual 38's on my setup can these F/A be modifyed easily to bolt to stock 38's?
did any 701's or 650's come with a single 38? or are all stock single setups 44's?
also what ski's came with single carbs (example, what do i search for on ebay to try and hunt some down? B1's, SN SJ's??? how about the wave runner 3, did it have a single carb 701?) i think this info might be useful to clear up some FAQ's that people might have.
and one more question, is there any advantage to running the single carb F/A on a dual carb setup or is it all just looks and preferance? are the dual carb F/A just as good? if the single carb F/A cannot be easily modifyed to fit a 38 then i guess i would need to use the dual carb F/A right?
my after market K&N's are falling apart so i thought i would give OEM a shot if i can get em cheap enough.
thanks
thanks
