Antigravity battery
hey guys,
I recently purchased a new battery and I have the charger from them too. I run a total loss system on my dvx. I wanted to know what should I do to make the battey last as much as possible. Should I charge it after each ride? What should I do exactly?
Would like to hear suggestions.
Thank you!
Stockton
I have mine elivated up off the engine bay floor 3 inches so it's not sitting in water. I take it out at the end of the day so the tray and battery can dry off. Iam recharging it at the end of the day or session, usually 2 tanks but a lot of starting so I Don't let drop below 13.3 before charging. If 50 degrees or colder out I'll warm it with a hair dryer bedore firing for first time that day. You could seal the seam around the top and around the posts, I didn't after 2 years the battery failed one day. I took it apart and had white powdery corrosion inside and 2 straps broken off 2 cells. I water tested the posts seams, no leaks, also the top seam was a MF to get apart so don't think it leaked either. Just looked like battery corrosion I guess. Theirs Mikey mouse clear silicone on bottom of the cells, tiny bit as shock insulation or something :(
To be honest those straps prolly broke when I opened the battery up.
