Any engine assembly guides online....
Cannibal
Tasty Human
Summit Lake, WA
Getting ready to put together my 61x/61x engine with Wiseco pistons and Kawi wrist pin bearings. I'm looking for a general guide for assembling (torque specs, sealant, tricks, tips, etc). I don't have a service manual, so if anyone knows of an online version, that would be great.
Also looking for specs on clearance for the Wisecos, ring gap, squish, etc.
Thanks,
Steve
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Oem base gasket, put on dry, 38-40 lbs of torque on the base bolts. Grease all bolts before installing.
if using a stock head use a Oem headgasket only, no aftermarkets for the headgasket.
O-ring heads can be greased or sealed with 1211 sealer. 21-24 ft-lbs on the stock headbolts. If using ADA head with the 10mm girdled studs, grease and torque to at least 36 ft-lbs.
Cannibal
Tasty Human
Summit Lake, WA
I know sbt has some simple little manuals that show what torque... let me find it....
Edit: Here ya go http://shopsbt.com/pdfs/y650701x.pdf
Thanks guys. That's a big help.
Chuck, do you happen to know the case half, flywheel, and coupler torque off the top of your head?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Case bolts 8mm-24 ft-lbs
Bed plate 10mm bolts 40 ft-lbs except the ear bolt on the starter boss 32 ft-lbs for it.
70 ft-lbs stock flywheel/ 65 for TBM
Coupler...Just good and tight with my tool and a 1/2 breaker bar, as couplers will tighten when running.
Cannibal
Tasty Human
Summit Lake, WA
Oh, and thanks for the specs Chuck. I'll have to make a quick ref chart with all this stuff on here.
