Super Jet any info on ada 850 cylinder???
snowxr
V watch your daughters V
Waterford, MI
ADA makes a couple billet cylinder kits. They both require stroker cranks and come unported, and unassembled. They need to have the sleeves installed, then bored to size. Not a do it yourself kit, but with the right investment in time/labor/parts they can be built into a great engine.
IMO, buying a DASA or Team Scream stock stroke 850 or 900 would be smart. Bolt in, burn gas.
The ADA kit is cheaper, even with the extra work. Just have a competent builder do the work. No power valves, so that's sure to turn lots of people off. I like mine.
That said, ADA is out of stock
i would definitely buy an dasa or xmetal, but i was wondering if anyone had info on those stock stroke ada? i'm a student at the moment and the price for a dasa 850 is still high for the moment but finding a cheaper alternative can be interesting
from what 3rid racing say :
It all starts with a lot of calculation... on paper... those cylinders were built for +5 +8 stroke... but there is room for modification... and we always wanted to make one... ADA Racing has been supporting us in this experimentation ... so let's rock the ada billet 850 SB... so maybe if they are supporting them on those modification they will come up with a new cylinder!!!
