Anyone know which spring for an R&D mount and UMI pole?
Tuscaloosa, AL
I know the UMI String will work with the R&D Bracket with a stock pole, dont see why a UMI Pole would not work. If the bracket has the spring holder tower, you have to cut part of the spring, if not you install it like normal, I ran this setup with an AC Pole, it was a bitch to install but worth it.
CuzzinOlaf
Hero of the Stupid
IL
I guess I'll have to bend the spring some... I never did that so I guess all I have to do is heat it up or put it in a vise. I'll add it to my list of winter stuff to do with the ski. Thanks. :Banane35:
sjetrider
This is correct, if you bend it it will work. I have seen it happen.
The stock spring will also work and much better than the stock spring on a stock bracket.
I would run the stock spring and tighten the pole if I had that bracket.
link
LFR
oz
I have this set up on my ski.
The stock spring is the one, just rotate it 180deg & cut off the extra inch (or not) have 3 skis in my crew with the R&D...all the same spring.
The UMI wont fit..
