I have a brand new never been put in the water Tiger Craft Aquabot. This ski has the best of the best, Starting with 1105CC power valve True Performance Engineering (TPE) motor, motor has all brand new cases, power house crank, power house intake with 49mm full spec carbs, MSD total loss Inside RRP ebox set up by (TPE), Power factor pipe, billet stator cover, billet couplers, Rhaas motor mounts with Kenny keepers, Jaz fuel tank, WPS light weight battery, dual 800gph pumps with switch, RRP Ninja hand pole with everything, RRP fat bars 50mm, 155 skat mag pump with 9/14 prop,(only aquabot with a 155 pump) thrust trim, No money spared on this build, SKI IS BRAND NEW STARTED JUST TO TEST ELECTRONICS BUT HAS NEVER BEEN IN THE WATER. I reserve the right to end action early do to ski being forsale local. any questions feel free to tex or call 609-352-1457 Jason Will ship at buyers expense.
HUMMMMM
