Yes, all the same and 100% interchangeable as long as the wires are long enough.
You can even use some of the Kawi coils that have the same general look.
I took a 650 motor and switched the electrical from a650-760 changed cdi, flywhee,stator and cover and ebox because ebox was bigger only kept the coil and recterfie/regulator from the 650
Only word of caution is some of the 650 coils have Resistor plug caps so you need to run non-resistor plugs. The later ones are non-resistor caps so they run resistor plugs.
