I am NOT here to argue..... You can build your pump any way you want. But, if you are going to advise others IMO it is wrong to do so in the manner you are doing it. This is the way I do it. I have 30+ years experience, have built thousands of pumps. (Kawaskai, Yamaha, Honda, Seadoo, Polaris, Etc.) Hundreds of Solas Yamaha pumps with no issues.
I have had MANY customers build pumps in the way you are doing it, and still have bearing failures. When I build the pump for them, their problems all go away.
Here is how I do it;
1 - freeze the shaft.
2 - clean all oil from new bearings, warm and install BOTH bearings on the shaft by hand. NO press, or hammer needed.
3 - completely pack bearings and cavity between bearings with grease.
4 - again cool shaft and bearings
5 - install front seal in the pump
6 - warm pump housing
7 - install shaft, bearings into pump housing again BY hand. No hammer, or press
By doing it this way you are not putting ANY lateral force or stress on the bearings.
I will say, OE aluminum pumps are more forgiving. This is the way I build all Yamaha Pumps, but is most curtail with a stainless housing.
