Other Atp flame installation help
onlyFX-1
Jace Forest...BRAP!
So I'm having problems understanding the instructions for this flame ignition.
There are 4 wires running from the pickup plate, white, brown and 2 blacks. Later on in the instructions it shows a pic of the pickup plate installed and it has 2 additional green wires. Where did these come from? Also it says "black of pickup to any ground point in the ebox", where does the second black wire from the pickup plate connect to?
motozachl
uPsiDeDoWn
JAX
Those green wires are the original wire harness which makes it extremely confusing. Just run new wires completely from the pickup.
Brown of pickup - brown/white of cdi
White of pickup - red/white of cdi
Black of pickup - ground
Are you going to be using the switch to run two tunes? I didnt
onlyFX-1
Jace Forest...BRAP!
I'm not gonna put a switch in because my second curve is for when I get a powerfactor pipe which wont happen for a while.
So just ignore the pic with the green wires and just worry about what is wired to the pickup plate? I know that one of the black wires goes to a ground, where does the second black wire go, just ground it as well? In the instructions they mention 3 wires on the pickup plate but I have 4
Do youself a HUGE favor, If you have any questions go directly to the manufacturer! Not saying motozachi is incorrect, but PM Chris at ATP and he will answer all of your questions, problems, and concerns. His name here on the boards is QJS. After all you did pay for the product and along with the product comes ATP support which they are happy to provide. Hope you get it all sorted out!
Watty
Random Performance
Australia
Both of those are grounds. The black attached to the pickup plate grounds the e-box itself. The black from the pickup runs up and into one of the ground points in the e-box. You could in theory attach this black wire directly to the pickup plate, but then you would have to plug up one of the holes in the grommet. The same can be said for the two green wires. They aren't used, but it you have them there, it keeps everything looking stock, and you don't have 2 holes in the grommet to block.
The idea though is to use one of the green wires as a ground wire for the pickup itself...again, looks stock.
So...
Brown (pu) - Brown/White
White (pu) - White/Red
Black (pu) - Green (connect to ground inside e-box)
Other Green is not used
Black wire running from e-box to stator (as per oem) attaches to pickup plate
onlyFX-1
Jace Forest...BRAP!
I did try to send chris a message but his inbox is full. I was just trying to make it to the lake today that's why I made a post. Plus their instruction are a little hard to follow so I figured someone else must have had the same questions as me.
Thanks for the responses!
