Aura pole bolt spacer?
OCD Solutions
Rentz, GA
I have an RRP spacer here from a billet pole that is 5.174" wide if that helps you at all.
The spacing of the cast pole is wider at 5.25".
The billet spacer is narrower so you could go with it and use shims to make up the difference if any.
