B Pipe head bolt size/ cant get a wrench in there.
So what bolt or stud/nut combo do you guys use to bolt the manifold to the engine on those top two midles holes that have the slot on them? Went to hardware store and couldnt find poop that would work let alone get a wrench to fit around a nut or flanged bolt.
any help is appreciated!
N3vrSat1sfied
Military Member
Fort Worth, TX
need to grind down a wrench like this
index.php
http://www.x-h2o.com/index.php?attachments/2012-11-13-23-56-18-jpg.202282/
kinda figured that is were it was going. will have to order that size bolt. mine is on the 62t which has larger bolts i do believe? cant i just put a helicoil in there and use the smaller size bolt w/ a smaller head like the 61x?
