Other B pipe install tricks ????????
Use OEM bolts with 12mm heads.
Then take a 12mm wrench (DUH) and grind down the sides a bit.
That should be enough to get those bolts tight.
chad
I pretty much love beer
The manifold is slotted so installl those 2 bolts first to where the manifold just barely slids in, so that you don't need to turn them much. Then do what matt E said
