B pipe problems
Hey guys anyone ever have issue with the factory b pipe, my pipe keeps blowing apart off the cast head pipe I've got the hose clams on both pipe and head pipe tight but only after 5 min of riding will blow apart and will re install. It keeps happing. Going to change clamps tommorrow to try out but looking to see if anyone had similar issues
Had a local riding buddy experience this year's ago. He was running cheaper (thinner) couplers. Switched back to 4 ply couplings, made sure they were the right length (too short and the clamps squeeze it off when tightened), and made sure the head pipe and chamber surfaces were clean and dry when installing to remedy.
Tuscaloosa, AL
Bought a new BPipe last year with a different type coupler. Went on easy and popped r8ght off just as easy...
Sent from my SAMSUNG-SM-G930A using Tapatalk
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Cleanliness is definitely a key factor. The pipe surfaces that the coupler clamps over need to be degreased thoroughly and so does the coupler. If a lubricant is needed for installation it should be windex or soapy water, NOTHING petroleum based.
