- Ontario, Canada
So I am in the process of parting together a B-pipe. I have acquired a manifold for a decent price and a head pipe to borrow until I can afford to find a replacement. My last prospect is the chamber. I have read as many recommendations for the mod chamber as I have for the limited and now it is all out confusion to me lol. From what I understand, the limited chamber was built for back in the day to compliment the old 61x/61x 635's? 650's and 701's. I can't quite remember what I read in regards to that reason but I believe it was something along the lines of because the 61x setups were only capable of so much, the extended chamber was needed to complete the powerband required for a winning combination both on the course and for freeride use.
The mod chamber was developed after the 61x/62t platform surfaced because that combo is able to utilize the shorter chamber with the same results that the limited chamber produced. It was apparently cut down for 61x/62t 701's and up into the big bores. I am on the edge of ordering in a chamber but would like a little clarification on this if I could please. I saw in an older post, not sure when it was done, but Chuck from X-Scream said for racing and top end, mod chamber. For freeride and freestyle, limited chamber. I hate having to ask this, but I have tried searching and as much as I have found, I have not been able to determine what chamber truly applies to what setup. I am coming from a Speedwerx dry pipe that took a little...ummm..."break" from service life for an undetermined period of time. So I am most used to how that pipe responded. It was more of a 2/3 to full throttle performer. It did always seem to have a slight flat spot on the bottom end though. Would the mod chamber be that "best balance" transition for me and my setup? I can't help but think that if I go for the limited chamber my throttle response might be too low on the powerband and I won't get the pump to fully prime. Here is the most notable of my engine and mods...
701 61x/62t stock bore SuperJet
stock electronics...maybe keeping my enhancer if I ever hear back from MSD in a timely fashion
ADA head with 37cc domes soon to change to 35's now that I am no longer on a dry pipe
ported exhaust and cases
stock intake and carbs with boyesen pro series reeds
hooker 9/15 with stock but blueprinted pump and pump stuffer core
Thanks very much for your input guys, this is a really tough expense for me to absorb, I just want to know that when I buy it is with confidence that it is the right way to go.
