B pipe water screw settings
hey buds, I have a stock 750 xi engine. dual stock carbs. Whats the hot low end set up for the water injection srews? I have a blaster limited pipe. Right now, i have the top open 3/4 turn, and the other closed. thx, Danno
Motorheads5
Livin the generation gap
ketchikan alaska
OK I'll go first you are right where everyone has felt safe it feel's good there .
what waterbox are you running and do you have any stinger mod's ? basically run it as dry as you can without melting anything savvy.
Crab
thanks darin...noswad!
Seattle
Only part true Craiger, on my RN I run the top screw way open for maximum bottom end, makes a big difference. On the X2 I run fairly dry to get some rpm with the Blaster chamber. You have to tune for your setup. But my tuning did respond much better with the x2 and a dryer pipe. I can't wait to see how my 701 is going to work in there.
hey, thanks for the response buds. I am running a stock water box. I saw somewhere that one guy was running it with 3 turns open. That took me buy surprise. On my 750sx, i would run it with the top open about 3/4 for bottom end. Thanks again, Danno
