NelsonLt1
XXX
- Shoreacres, TX
Are there any other steering cables that will work on a B1? (Raider, B2, SJ, etc...) I'm wanting something a stronger than stock for the 1100 B1 I'm building.
Thanks,
Luke
Thanks,
Luke
might wanna contact godocgo on this one.
i highly doubt it, most people are all talk. you will end up owning 23 of these forever
besides most people don't need a b2 cable. you only need it when you build big hp motors.
a simple trick is to put a steel sleeve over the the rear of the cable, the cable bends on the outer housing when pushed to full extension in a high speed turn.
you need the 1997 b2 cable. it is 2mm thicker. may need to get a bigger thru hull cable piece. the bigger problem is the steering cable holder under the hood. you might be able to make the stock bracket work with some dremel help.
I was looking at a VXR Pro cable I had. It is just about the same but had more throw that the b1 cable. I want to amplify my nozzle trhow for surf riding.
More people wanted aluminum than stainless. It doesn't look like I can get them in aluminum. Stainless only. Still working on the minimums and length/pressure specs.
