What are signs/symptoms of a faulty rectifier? I've gone through my electrics from top to bottom with a volt meter and everything checks out minus the numbers for the rectifier. They're off a bit from the manual specs but it worked fine when I parked it this January after Daytona. I put in a new ATP Epic this winter (sold my last one). I've installed two now and it's wired up like the manual states. When I have it all buttoned up there's no signal or anything when the start button is pressed. No clicks, no buzz, nothing. I'm at a loss. With the relay powered up directly (not jumping the relay, but powering it) the ski turns over like normal. With everything checking out I'm assuming it's the rectifier. Any ideas?
Items ruled out:
Battery - fresh and topped off
Start/Stop Switch- meets all Ohm tests
Stator - Pulser coil WNL, Charge coil WNL, Lighting Coil 1.6 - 1.7 Ohms (specs = 1.2-1.3 Ohms)
CDI/Epic - checks out and brand new, wiring triple checked
Relay - turns the engine over fine when powered up directly through brown/black
Coil - 1 year old JSS coil and meets specs per volt meter
Starter - good to go...turns over engine fine with relay jumped or powered
Connections - all fresh and fully lubed with dielectric grease
Items ruled out:
