Oh yeah, I should have mentioned mine has been heavely reinforced inside and has had the pump mod done with alot of extra reinforcing in the tray area, maybe its water logged too, IDK.
Just weighed mine. Turf, pump shoe, nose foam, and tom21 sponsons = 87lbs. I know my foam is wet, though. Hood with filled extinguisher compartment = 11lbs.
My signature has my build from last year. I was 89lbs after defoam with hood. After foam was 97lbs. Before that I was 115 with hood, turf and shoe. Somewhere between all of our weights you will find your answer. It's like a bad 5th grade story problem.
