kawishaul
I bleed GREEN!
- lake City, FL
I have a Ocean pro cylinder and the included base gasket is plastic. Should I put some sealant on the gasket? Or can I run the base gasket that came for Wiseco? I was told I had to run the base gasket maybe for squish. plastic or poly gasket 1.6mm wiseco .5mm
I guess this would change port timing also. I need help fast!!! Thomas
