Thank you very much for the help!
According to him he was riding it 3 weeks ago then water started leaking into the cylinder. I have yet to see it though, he posted it for sale then went out of town for a week.
It also has some aftermarket parts that the guy he got it from installed.
Oddly though he claims the title says its a '93 fx-1?
It will be my first ski, I've heard fx1's can be tricky to ride though. So I'm a little worried.
He wants 1000$ for it, says the hulls in good shape and has stock paint and stickers even.
Is there anything I should really look out for when I go check it out?
Far as I know fx1 is 94 only! Could be his error an error on the title is just as likely, once they are titled they don't really care anymore.
No need to worry about it being tricky to ride, fx1's come with plenty of power...701 driven which is the starting platform for jet ski freeride/freestyle. Just remember to give throttle to turn and if you start to lean too far. You will get a great work out and have a blast man. 1000 is a good price. Usually air leaks can be corrected with an engine gasket set and making sure fuel line and filters work properly. Most information on that is in the fx1 shop manual linked to above. Even if you buy and it has problems they can be fixed relatively cheap.
You can ask for a compression test which will tell you if the motor needs top end rebuild. 150/150 is factory, if each whole is equal or 1 or 2 off of each other you are in good shape with the buy, I'd say.
Keep in mind I'm still learning myself listen to the advice here given by people it is usually great here. I have bought a ski with bad air leaks in the past. A good indicator is if on trailer start the engine free revs up or if on multiple starts the idle is inconsistent.
