Super Jet Battery not charging
Barrie, ON
Guys...I need some fresh eyes on this charging problem I'm having. I cant seem to find out why my battery is not charging. It's a new build with all new JSS stator and advent ignition. I'm geting 24-40VAC from the green stator wires and 1.2 ohms between them. JSS says this is good. I measured the voltage coming out of the voltage regulator and I'm getting 4.5 VDC. I thought this might have been my problem but I changed it and am still getting the same. JSS also said that voltage regulators wont work properly until hooked up the a battery. All the connections are good. Ground is good. Battery is a new shorai. I'm baffled.
I think the voltage regulators I'm using came from 61x ignitions and now i'm using them on a 62t setup. Could that be it?
