Blaster Battery time! woot woot
Ok, I think I'm wanting to stay away from Neverstarts, They usually last me about 6 months, but the last one lasted since 2010, not bad! but I have not been riding near as much as I used to and I use a tender, I'm also eating a chicken tender right now too, mmmmmmmm.
I did a integrity check today and it didn't stay strong for more than 5 cranking seconds and started fizzing dam near like a mentos and diet coke going off.
SOOOOOO, I have just heard via the idiotnet that Deka batteries and are supposed to be very good and Oreilly batteries are Deka brand. I haven't heard of Deka before.
http://www.oreillyauto.com/site/c/d...Search_battery+atv_-1_448&keyword=battery+atv
I got mine for my SX650 from advance auto for around 50 after a coupon The AGM like that. But I have not had it long to tell if its good or not
Deka's are bulletproof..I have some that were pulled out of skis I parted out...and they were near dead when I got them. They still charge up to 100% and hold charge without issues...some of these have been going for years(after I got them used). I also have some Extreme Magna Power batteries that are the same way. They look identical to the Deka's but im not sure on their manufacturer.
The shop I buy mine from said they have done test on these batteries and they exceeded the rated CCA by quite a bit..I want to say they got around 500 CCA..but I could be off on that number as its been a couple years since they told me their results.
yamanube
This Is The Way
Staff member
Mandalor
I have been running a Big Crank AGM from batterymart.com for a couple years now and its been real good to me, cheap too. Looks to be the same as most of the other restickered AGMs out there. Whatever you buy make sure it has solid terminals, no sense in buying a 3-4 year battery with terminals that may only last 2.
I would also stay away from Odessey batts, they are crazy powerful but quite a few members (myself included) have had them prematurely fail just outside of warranty.
Battery Deals at Advance Auto.
The Deka AGM it is.
Your the best!
BIG30 is the coupon I used and it was $30 off. So $65 out the door and I'm about to pick it up. Just order it online and select in store pick up. Then google "Advance Auto Promo code". They have a bunch.
