Super Jet Beau's RN (rocker kit)
Yami-Rider
TigerCraft FV-PRO
Texoma
Im rebuilding a 97 RN hull that one of my riding buddies bought. Its in pretty rough shape, has a lot of patches from the many previous owner and was also in a car accident recently, so i am putting a rocker kit on to fix the broken nose. Beau also plans on putting a GP800 engine in this ski.
Yami-Rider
TigerCraft FV-PRO
Texoma
Solid resin on the bottom of the ski, easily removed with puddle knife and a hammer.
Rocker kit didnt come with any templates or instructions, so i just started cutting away, this is what i end up with.
More damage found after removing the solid coat of resin.
From the inside
Yami-Rider
TigerCraft FV-PRO
Texoma
Removing old patches, they didn't even remove the spray paint before glassing....the paint underneath the glass made for easy removal of the fiberglass.
Yami-Rider
TigerCraft FV-PRO
Texoma
Cleaned/prepped inside for glass.
Mixed up some west system epoxy with chopped up fiberglass fibers to make a strong glue.
Glued/riveted rocker kit on.
Removed rivets once the epoxy dried
Yami-Rider
TigerCraft FV-PRO
Texoma
Where did that rocker kit come from?
We don't know. Came with the ski. It was paper thin and was not symmetrical, but nothing a little bit of fiberglass and sanding cant fix.
Thank you for blocking off that front exhaust!
Ya, Boe was thinking about keeping it, but i told him it had to go. I have rode two skis with front exhaust and it sucked.
Yami-Rider
TigerCraft FV-PRO
Texoma
Port and starboard side glassed up.
Found some more damage, cracked all the way threw the fiberglass on the outer side of the gunwhale.
Myk
Garland, tx.
A dude from here made that rockered nose. I'm sure glad you're being so thorough with this ski. Your buddy was a real cool cat. If u guys need anything just holler at me. I wanna see this ski on texoma this year!!
Yami-Rider
TigerCraft FV-PRO
Texoma
I didnt know Boe bought the ski from you. We should have it done by this summer. You may remember me, i jumped your wake board boat wave like 100+ times at Texoma on my 98 SJ.
