FX-1 Before and After Motor Build
wi
Hey everyone, today we finally assembled my motor after a complete rebuild. Here are some before and after pictures.
The motor is as follows:
735cc
Ported 83mm 61x cylinders
Worked 61x cases
Pro-x pistons
New crank
Ported factory b-pipe w/ fx1 chamber
Sprayer bar on fp chamber
Blackish ada girdled head w/ 35cc domes
Jetmaniac head bolt kit
Boyesen power reeds
Boyesen crank seals
lightened 61x flywheel by php
Dual cooling
Hot products Tornado flame arrestor
Advanced timing
wi
That's a sweet motor. How much did the port and case work cost?
Thanks! One of my good friends really helped me out a lot on the porting and case work because i didnt expect to need a new crank. Being 17 and without a job it really set me back, so he did the porting for really cheap.
wi
Although the flywheel cover looks black we put a little overspray on it to make the orange come out in the sun. (Hopefully this picture worked, using tapatalk)
Sent from my iPhone 4s using Tapatalk
wi
lined up the motors paul was working on.
on the left is a 760 for steves bob: ported, full specs, total loss, and a speedwerx pipe.
middle is my motor: 735
and on the right is my brothers motor: limited 701
wi
looks good, what did you use for paint on the engine and pipe?
Didnt paint the pipe, just used a metal polish but it turned it a dark chrome.
Painted the motor with Vht high temp engine metallic burnt copper (sp402), a lot of clear coat and a self etching primer. The black parts are gloss black engine enamel and clear. The motor was blasted and prepped pretty well, but still did a lot of coats for a good finish.
wi
Got the motor in and started up. Ill see if I can post a video of it running.
swapmeet
Brotastic
Arlington TX
That VHT burnt copper is getting around! Looks sharp! I like the black bed plates a lot, makes me want to do the same. Maybe after the season is over.
wi
I copied you, sorry! Haha orange has always been my favorite color so after seeing your build I had to paint it this color. Thanks though!
wi
Getting 205/207 for compression... Don't want to run race gas so I need the domes cut.
CT
Your getting 205 and 207 with the 35cc domes? Might want to try a different compression gauge. You should be around 185 at sea level
CT
Bore shouldnt effect it but I the porting might lower it.
For example I have a 62T/61x 83mm bore and ported by PHP with 35cc domes and im at 175 at sea level.
