- Idaho
Ive narrowed down my issue, but now im just not sure why it is occurring.
I hit the egnition switch and the starter only engages for a second, then spins freely.
I thought it was a starter so I bought a new starter - but it does the same thing.
So i took the flywheel cover off and i see that the smaller gear (bendix) is literally sitting behind the larger gear. I guess the gears line up for only a second then the bendix ends up behind the main gear, I can line them up so the gears are joined, but then when i start it up the bendix emediatly goes behind the main gear and spins freely.
What needs to be done here?
