Custom/Hybrid Best battery with stock electrics?
I know this probably has been answered but dont have time to search. I have been running oddysey batteries which I love, but would like to relocate to the firewall, and this will not fit. What would be the best battery to get that is maybe a tad smaller but still powerful. I still run stock electrics.
Worked best for me because of the powerfactor pipe and waterbox.
I run a stock tank and B pipe, just wondered if it would be worth the difficulty of getting to the battery, to get the weight back, also it is a -4.3 superfreak, . I guess either way I need a lighter battery oddysey weighs like 13lbs!
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
what odyssey are you running? I ran a PC545 for a long time.
Currently run a Deka EXT9 with good results.
Relocation to the FW seems like a PITA.
I think its a pc 620, but not positive since I'm not at home, my ski was setup for a power factor, but was able to get by with the inserts where they were other than the battery, so I made a carbon box to glue in but now I am having second thoughts about glueing it in stock location. Its just a ported 701 but rips in this hull! Maybe I will just add inserts and use straps for now as that would be easier to remove than the box I waisted time making, just wondered what peeps thought about moving the battery to the firewall, and what battery would be best?
I'm running a etx9 right now but I just bought a ballistics
Im running stock location and with how light the battery is I don't think it goi g to make much weight difference, plus I heard mounting against the firewall is a big hassle when taking it out
Mine is super easy to reach and one strap holds it in, but again the pfpipe makes it much roomier on that side!
NC
etx9 worked for a bit then it started to die and left me stranded, so i gave it to my friend in his WB1 and he has not had 1 problem which is weird. But right now i have the next size up etx12 and zero problems I can not charge it for 2 weeks and it always starts up.
