Freestyle Best Engine Size for Rickter FS-2 Evo 1
Hi Guys,
I'm looking for some advice regarding the best engine size for a Rickter FS-2 Evo. My real criteria is to be able to do a flat water back-flip using a small wake and a jet trim system. I'm around 190lbs and 5'11". I've been advised that a DASA 850 cc will be sufficient but do not want to be overpowered. I'm against the 1100cc as this could not be bored if I had a failure.
Reliability is also important.
Thanks in advance.
Proformance1
Liquid Insanity
Vendor Account
New York Crew
1100 can be bored, Im about the same size. FR2 Evo 1 I have currently. If you have trim and a good size wake or surf you should be fine with most motors. After that it becomes time and skill. it is not a given to do a BF off a .5 meter wave with an 1100 in a 50 lb hull. Skill is a huge factor. If you are mainly concerned with FW BF an XFS is more in line and with an 850 and much practice you can get a few under your belt. I also have an 1100 in a KDX Xscream hull with TL and mag pump, etc. Havent FWBF it yet but have only ridden it once
Thanks for the reply. I can get a 950cc DASA for 1,500 bucks more. Do you think I should go down this route. I understand the XFS is much shorter and is different riding experience to the FR and FS skis? I also like to cruise around and explore places with my ski. Thanks in advance, your advice is much appreciated.
Mike
Proformance1
Liquid Insanity
Vendor Account
New York Crew
Your asking the wrong guy, lol I have a 971 DASA in my surf Evo and an 1100 DASA in my FW ski so I think go big or go home, but hp is no match for skills. I have seen Chris on here FW BF a -2" Wamiltons SJ with a 760. The only ski I have ever FW BF had a 1200 in it. IMO you are better off to start small and learn the skills then work up. Dont forget one major fact, are you building yourself or having a pro build and tune for you? If you are building yourself and are asking these types of questions most likely you will leave a bunch of undiscovered power in the ski. Pros can tune a 900 to rip better than a lot of 1100 or even 1200's
Moto360
Torrent Pumps
Pennellville, NY
I have a XFR with a DASA 850 and a dry pipe. Yes it can be Flatwater Backfliped. But I does not rec. ride very well.
If you want to Flatwater back flip and go out for a cruise and explore, IMO you are going to need 2 hulls. The XFR is very unstable at speed and requires a lot of body english to keep it up right at speed. Hense the reason I bought a FR2 Evo 1. Not together yet but have rode Performance1's EVO.
Don't necessarily need two hulls. A Superfreak Badass with large enough motor, B-Pipe so you can get the stock tank in there and bam! Perfectly able to rec-ride and flatwater flip.
Pablo
sqeez bth levrs & lean bk
georgia
Agreed. If I do it all over again Jetmaniacs personal ski is the way to do it. Strong enough, light enough, and reliable enough.
I have a Rickter FR2 which is a bit heavier than the FS2, Has a dasa 850, mag pump with a 10/16 hooker and it will not f.w.b.f. It just does not go high enough so it always hits the nose on rotation but with a good boat wake it works. On the plus side the ski is absolutely awesome and I love it enough that I'm selling my my BOB gen 2 that will f.w.b.f.
I also agree bigger the better, but I also say depending on your skill level a bigger motor will only slow your progress because it will kick your butt every day!
