Hey guys just in the process of building a flatwater freestyle ski from my 2010 Superjet..
Built up a new hull from the SJ in carbon, cut back 400mm and brought up the rocker an extra 150mm! Hull weighs a tad over 20kg
I want to try and make this a good flatwater hull without going big bore so just want to know what other mods would be worthwhile for bottom end only..
still have to decide on a new prop and pitch but also considering a mag pump w/trim, specific for the engine mods I end up doing..
Here is a list of mods that I've already done!
701 Ported for bottom end freestyle only
ADA Head @ 190psi
TBM II Lightweight Flywheel
Factory Pipe Limited Chamber
MSD Enhancer
Tauceti flame arrestors on 38SBN's
Vforce2 reeds on epoxied Intake
So for engine-wise first, what mods would make the biggest bottom end boosts?
Bigger carbs? ATP Ignition? and small things like light-weight couplers, pump cone?
On the pump end.. what pitch prop on stock pump would go best, if not a mag pump (140-146mm on what pitch too?)
Any comments or suggestions would be greatly apprecited.. will soon follow up with pics too!!
ADA Head @ 190psi
MSD Enhancer
