Best Overall Prop
nokfir
Merrick NY
i dont know too much about impellar pitch, so which impellar would be the best overall rounded performance. i ride alot of different conditions.i ride flatwater laps with wide open throttle alot as well as surf and rough water too.. i basically want a prop that will give me more bottom end and not sacrifice any of my top speed. is there a prop that does both? any ideas?
Intarweb flavor of the week! Hooker of course! :headbang:
There are many good choices out there.
If you had a pro build your engine, get their advice.
I run a Skat Swirl and am very happy.
I use a 12/17 (maybe 12/16?) Skat C75 big hub, cut back 5mm. 701, 185psi, enhancer, b-pipe, etc. Seems to work good for me and always stays hooked up.
Not to threadjack, but as a comparison: would a Hooker be any better?
Tuscaloosa, AL
If your ski is stock, I would contact Dave at IMPROS and see what he recommends. A Solas "I" prop would work well. A SKAT Freeride swirl would work well, may need to have it turned down from a 12-17 to a 10-15 / 11-16. A Hooker 9-15 may work well.
nokfir
Merrick NY
I would run a 12/17 freeride SKAT-TRAK. You'll be stoked
taylor, will that prop be good on flatwater also? i would say i ride 60% flat and 40% surf. would this bee a good overall prop? im really jsut looking for somthing that will give me more bottom end and no sacrifice any top. let me know thanks guys
BruceSki
Formerly Motoman25
Long Island
kafir.. i used to run a TBM pump cone and cutback 12/17 big hub prop in my sj last year.(thats in my blaster now) and ive got an 08 SJ prop in the superjet now.
it ran 49-50 mph on radar with a pipe, head, and flow control last year with plenty of bottom too.
i would recommend that prop(12/17 skat c75) or try a hooker. I have only heard good about the hooker so far. you would be the first in our group to run one.
just make sure to get a prop that will suit your needs when you get a pipe and a head on your ski, otherwise you will have to send it back to get repitched.
cookerq62
Life's Been Good
Upper Bucks, PA
I had one of these in my old boat that was tuned & cut back by impros. It worked great with & without a wet wolf cone. I ran it on a few different engine & nozzle combinations and it always performed well. Try to get something thats cut back if you can. Also SBT does an awesome job of refurbishing damaged or worn props for $25 so if you find one thats boogered up just have them repair it.
Indiana
I just swaped a solas I prop to a hooker this weekend and I'm not sold on it. I need to call Dave at Impros tomorrow and figure something out.
