best tool for sanding before reinforcement?
#ZERO
Beach Bum
Florida - U.S.A.
An Ingersoll Rand 6" orbital palm sander works great for grinding down the ribs and sanding for reinforcement.
You can start with 40 ~ 80 grit for the ribs and work up to 180 grit for smoothing.
Ericfox
Do it twice?That's DooDoo
<$20 4" grinder at harbor freight and some 32 and 60 grit flap sanding wheels.... just be careful not to get carried away or let the grinder slip.... it cuts through like butter if not careful which way the grinder is angled as you are working.... it worked great on mine and like said above just use some elbow grease for the nose and angled areas
LBE
Eddie Would Go.
Charlotte, NC
You're a tool!! HA! :lmao:
36 grit on a Riobi or Dewalt grinder, only 30 bucks at HD. Carefull, the grinder removes skin as easily as fiberglass. I know
