SXR Best way to remobe glue from seams
hey y'all. New to this forum. I was wanting to remove the excess glue from the seams of my '10 SXR. What is the easiest way to do this? that stuff is like a rock.
Thanks guys
OptimaRacing
Jet zoomers
Thanks guys. Kinda sounds like everyone has their own way. Guess a twelve pack and some elbow grease is the best way
Less elbow grease and more power! Use the diegrinder method if you have one or the multi-tool (shovel head looking things that are trendy right now). If you don't own one and won't be using it after this Harbor Freight sells a cheapo POS one that will work well enough to remove that tough ass glue:
http://www.harborfreight.com/multifunction-power-tool-single-speed-oscillating-16-amp-68861.html
High roller Harbor Freight version:
http://www.harborfreight.com/variable-speed-multifunction-power-tool-67537.html
Get some extra flat teeth blades to go along with it, the glue will wear them down.
