Since I'm waiting on my hull, I've had lots of time to think about various scenarios... My latest thought is one big bore cylinders. From what I've read, the 61x cylinder would make a better BB cylinder for freestyle than the 760 cylinders but obviously the cylinder itself (not the sleeve) would need to be bored prior to installing the BB sleeves.
My question is, when you bore the cylinder, is it as simple as just taking the cylinder to a machine shop, boring the cylinder, and dropping the sleeve in or is this really something that needs to be left to the professional engine builders so that all the intake and exhaust ports are sized properly for the larger bore?
