SX/SXi/SXi Pro Big pin motor?
I just purchased an 98 sxi pro this spring and could someone help me understand what a big pin motor is I read about periodically, benefits, and how to tell if mine is?
" Big Pin " refers to the wrist diameter on the 95 and later engines. they have 22mm pin verses 20mm on the earlier models.
Luke6.38 be careful when buying parts for the late model sxi pro's, a lot of parts are specific to the 98 to 02 models. I have 2 of them and have had to learn the hard way!!
thanks for the specifics here. my compression is around 135 each cylinder (the way i bought it) and am considering rebuilding / re-ringing it. If i need to have it bored, this info will be critical.
let me know if anything specific I should know additionally, especially if I end up looking for rebuild kits on line.
^ Big pins are considered a little more reliable also, check your compression with another guage if you can before you tear it apart unless you know yours is fairly accurate
my gage is pretty good, and have used it for years. I generally take multiple readings, and is very repeatable. Also saved me from making a bad purchase on another ski which wouldn't start when looking to buy it, and found the compression was 139 front, 95 back. Owner could only say it ran great last year. lol Mine ski runs very smooth, but would like to get the compression back to atleast where it was when new on a tight budget.
Wilke
X2 stole my life
Indialantic, FL
You're not that down on compression and you say they are pretty well matched, a fresh hone and new rings is probably all that is needed to get that 10-15psi or so back.
I believe it came at 179lbs compression new, so would think a jump of around 30lbs would be quite noticable. But if it only took new rings, that would save $ for other improvements!
Wilke
X2 stole my life
Indialantic, FL
You are reading it right, Not sure thats correct tho. The kawi service manual I have says compression pressure ranges from 125 to 193. I've never seen or heard of one being higher than 150-160 with a stock head, even after a fresh rebuild.
Good to know. Based on the past assumption that the 179 was correct, I was believing the motor was kind of tired. With limited funds, I may skip working on motor and look to adding a ss prop this winter to boost performance.
