Bilge wiring harness
waxhead
wannabe backflipper
gold coast
Have you guys seen our bilge wiring harness. its so much cleaner than having wires to your battery or breaking into your e-box. Simply plug it in and you have a power and an earth ready for you to hook your switch and bilge into .
waxhead
wannabe backflipper
gold coast
I will definitely be ordering this for my new build! Do you have a switch you recommend?
The normal hot products 3 way rotary switch. I have been trying to make a better one but i just cant at the moment. We are working on something but until its ready I will not release it
E350
Sacramento Delta
Wax, thanks for making that harness. I will be buying it for my next ski.
I have installed this Blowsion handlebar switch on at least three skis and have never had it fail:
Roseand
The Weaponizer
Wisconsin
This is such a clean option. I switched it to bullet connectors and ran an oem Yamaha style in line fuse in it. Using a surf Armour switch from @JetManiac
what bilge are you guys using these days that mount by the four bolts on the bottom of the strainer? used to use a rule 500 gph , but the old ones are discontinued.
The new ones have a different strainer that doesnt work with a lot of the bilge brackets...
Amazon Seaflo, I believe, is an exact copy of the old Rule….
waxhead
wannabe backflipper
gold coast
Thanks wax for a brilliant idea! View attachment 450052
Thanks for the feedback. I have been riding superjets since 1993 and cant believe no one came up with this idea before. I was building my own ski and was hating the wiring from the battery and.. well here was my solution
