billet adjustable pole
Can change the pole length and adjust the turn plate mount angle and is very strong and light~
thegoldenboy
RN Surgery... soon
Toronto
??? What problem?
The only thing questionable I see if the turnplate adjustable angle. Just seems like it would be hard to keep those bolts from moving, and if you did you'd never be able to get them loose without stripping the allen heads.
Other than that, sweet ass pole and i like the carbon/billet combo. Solid!
very nice. Hows the weight?
The 2 bolts on top of H frame near turn plate mount it will have 3 screw holes, Install 2 bolts in different hole to get the angle you want in 3 positions, I'll post more pics when is done. (Sorry for my bad english)
That pole needs a carbon brace in the middle on the underside tieing the pole togather.Those tubes are glued and pressed in to the billit peices.Correct me if im wrong.
Solution looking for a problem?
geez, darin! he didnt say it made 200 hp at 1400 rpms!
do you really see a problem with someone coming out with something new and different?
if everybody thought, "solution looking for a problem?", we'd all still be riding horseback with no saddles...... or even worse.... superjets with stock pipes!
NICE POLE GDJETSKI!!!!!!!!!!
THRUST
ThrustInnovations.com
looks beachithin to me . it is pretty much what i told rick to do 4 years ago . and the bottom looks a bit identical to rrp . the only problemn is the price everyone say rrp it to much money .How is the pricing considering it is coming from asia .
Ohio
I know I'm kinda guessing it can't be less than the XFT PRO (900.00 shipped).
But maybe....ya never know I guess.
We need a pole thread.
XFT glass=8.6lbs
XFT Pro=6.6lbs
Xmetal=
Stock=
RR=
AC=
U.M.I.=
WDK=
thegoldenboy
RN Surgery... soon
Toronto
Add ATP on there too. They are pretty light, stock like design, billet/carbon material.
