Jarrett Simmons
Blastersc
- San Diego
Just picked up a GP1200 with only 90hours, to drop the motor into what was my perfectly fine 96 blaster. My blaster 144 pump would need a rebuild so I'm looking at adding the 155pump from the gp1200 into the blaster. I've looked up some forums but I'm confused, would I just need the 155 waterdawgs pump shoe and the gp driveshaft? Is it worth the work, or should I just get a new sbt wear ring and prop for the 144? The trim on the 155 is tempting...
Plan is to have a strong reliable ski on a budget, deciding between glassing in the mounts to fit the new motor or just spending the money for the Ada plates.
