Blaster blaster 2 61x baster 2 factery pipe
yes, but the maniofld bolt holes on the 760 are 10mm and the 61x are 8mm. So you will have to drill out the cylinder bolt holes to make it work.
Maybe see if you can swap someone for a 61x manifold to make it easier.
i have seen a guy run a 760 manifold on a 701 but he took his time to line it up and was very careful not to move it when tightning he has been running it for 6 months with no troubles
