- New Jersey
I have made 2 different PVC stands. The first stand for my Super Jet is made of 2" PVC spaced 12" center to center. The strength of the PVC is acceptable, but barely. In addition the top vertical pipe at 8" is too long, it wants to flex out at the top.
I picked up a blaster a few days ago, and I need a work stand for it, so this time I used 3" PVC. As you can see from the photo the verticals are fitting to fitting except for the cross brace from the tee. It is 12 1/2" wide center to center. The dolly on the bottom is made with 3" harbor freight wheels, so I can move it around. Overall height is about 22". The PVC legs slide into end caps that are screwed into the dolly. I can remove the stand from the dolly, insert so 3" pipe legs and make it a non-movable cart if I like. The 2" stand will fit on the dolly also.
Nothing special about the stands, just thought I would share what we did.
