Blaster Footstrap Install
Status
Not open for further replies.
WaveDemon
Not Dead - Notable Member
Hell, Florida
I was asked to share how I installed footstraps in a blaster.
you'll need 2" wide Bar aluminum
12 small bolts and nuts (I don't remember the size)
footstraps http://www.kiteworld.net/shop/index.php?shop=&cat=87&itemid=604
bread knife
1 cut the bar aluminum a little longer than the footstraps will be when in stalled. it will be a backing plate.
2 pre drill the bar aluminum for the nuts and bolts.
3 use the pre drilled bar aluminum as a template to dril holes in the top deck of you blaster. location is up to you.
4 remove the battery box from the blaster
5 Cut the foam out of the blaster with a bread knife. The bread knife does a pretty good job of cutting the foam and not shreading it.
6 push bolts through and tighten nuts.
I tried using rivets and screws without backing plates and they just pull out.
Status
