Blaster Jetting
Okay y’all, I’m stuck on licorice here. Was told there was a forum on here but can’t find it, Called Factory Pipe and they had no leads or information sooooo.
Running a set of dual 44’s from a B2. 61x upper, 62Y lower.
Vforce 3 Carbon Fiber Reeds
Reed Spacer
Factory B pipe with a Mod Chamber
81mm 35cc domes, Riva Head
JM Lighted Flywheel.
Anybody know the specs for the carbs with this pipe?
N/S main, jet, and proper spring weight?
I’m thinking the N/S would be 2.0
Lost everywhere else.
Quinc
Buy a Superjet
California
I would start here:
125 Pilot jet
115 Main jet
Pop off 21-26 depending on what flame arrestor you are using. Higher if using stock arrestor.
http://www.x-h2o.com/index.php?threads/carburetor-specs-database-superjet-and-blaster-1.19403/
iu
