Blaster limp mode
What causes limp mode running and how do you correct it? Is there aensor, does the CDI keep defaulting into this mode after running for a couple minuted perfectly because of heat? Compression is fine, everything in fine, it has to be electrical now.
SuperJETT
none
The overheat sensor in the head makes connection inside and the cdi limits you to 2800rpm. You can also just have the wires shorted to cause it.
Disconnect it inside the electrical box, tape up the wires and keep an eye on temps.
