Blaster blaster problems with missfire
so took it out today ran fine for about 1 hour ish stop for a chat on beach , then went back and from hitting the start button felt like heavy bad missfiring and no power through all ranges
have rebuilt engine ,new coil ,swaped stator , loads of new plugs, loads of plug caps now on msd ,swaped cdi !! driving me mad ,its like this all the time , any ideas guys please ??
GREECE
Are you using your stock pipe ?? if yes do you get one of your 2 plugs wet with a milkish foam when this happens ??
If thats yes for both questions your oem exhaust chamber has a internal leak and water is returning to one of the cylindrs when you stop the engine,thats what happend to b1 and I had a real hard time getting rid of that missfire.
Good luck hope you get in the water again soon.
Pavlos
was both 155psi tested after new top end 2 months ago , sprayed ht leads tonight in dark wit saltwater which are new, saw some orange sparks in different places , that the problem ??
