Blaster prop
Seattle
I have an 08+ SJ that is running stock prop, my blaster is running stock as well.
I was thinking of getting a hooker for my SJ (limited, head, zeel, bored carbs)
And moving the stock 08+ to my blaster (bone stock)
Could always get the stock 08+ prop pitched a little bit. Thoughts ?
Alabama
Both of those impellers are good impellers. I doubt you would see much improvement making any of those changes unless your impellers are damaged. Try swapping the superjet impeller into the blaster and see what you think.
