You have the Hull. Glued to the hull is a left and right plate each with 2 mounts that the motor plate bolts to… Any idea what these SMC(is it SMC?) plates are called?
Anyhow, my Left plate (toward the front center of the hull) has stated to come unglued. It seems like the only way to properly fix this is to completely remove the plate to thuroly clean under it and then re glue it…. Anyone ever experience this? I believe it happened because of the ski when on the trailer bunks seems to have most of it weight right under the motor and it flexes the hull. I am in the process of making a bunk system that more evenly spreads the weight on the hull, for example, a support under the nose of the hull.
But I need to now pull the motor and fix this glued on SMC(?) plate.
