SXR blowsion thrust force pump cone...
Shonuff
I've got the glow
Memphis
I'm running a TBM pump cone and it's the same thing. It's a good mod and worth the effort. You'll have to pull the pump and the prop to install it so make sure you have a prop tool.
STL
It goes on top of the oem pump like a sleeve to make the hub diameter bigger = more pressure for better efficiency. It supposed to keep you hooked up better. And the TBM comes with 3 pump cone shapes for freestyle, top, end, etc... I will be getting the TBM before next season. I havent rode with one yet, but I have gotten a general consensus that this is a good upgrade
Idaho
Yup, I saw a noticeable improvement in hookup when I installed my TBM one. Keep an eye out for a used one. They should be popping up now the WF is over.
Its the poor mans mag pump.
That with a big hub swirl prop!
Mag pumps are like $1,700 so $300 for a stuffer doesnt sound bad to me. I have them in 3 of my skis.
