- Sherbrooke,Qc,Canada
I know some of this as been discussed before but I need to take a decision on my build for this winter. I have to re-foam my tray and wanted to do it using the blue faom. I was telling myself that while all this is opened up I might as well install BOB ajustable holds and transform my SN into somthing a bit different with the larger tray and everything. I have 3 main interrogations that I can't seem to answer even after searching for hours on forums
1- Excaclty how does BOB holds compare with normal (like WCS or Toby/615) ?? is the larger tray and adjustability really worth $250 more ?
2- I have absolutly no experience in composites, fiber etc. What materials I should use to do this kind of job ?
3- Considering I may uprage to an aftermarket hull in the a near future when my skills are enaugh to master the RN hull is all this trouble of re-faoming, bob holds etc really worth it ? Should I just only dry out the ski, install 615 holds, returf and be happy with this for now ? Or maybe the BOB holds will transform enaugh the SN so I'll want to hang on it for a liitle longer ?
Thanks in advance for any advice !
