Quinc
Buy a Superjet
- California
Not riding much flatwater anymore so putting her up for sale. Ski is bullet proof. Completely torn down and reinforced with 4oz, 6oz and 12oz s-glass, new closed cell foam, new water and trim lines etc. Every part was bought either new or like new condition at the time of the build. Every thread and bolt was cleaned/chased before being installed. Ski has a ton of power and starts right up every time. Easily flips and rolls, runs on 91 octane. Shes fogged and stored in the garage with the hood off after each ride. You will spend the summer riding and not wrenching with this ski.
Ski clinic bob Gen 3 comp carbon hull
771cc CPT ported cylinder and cases: 760 based, pro-x pistons, wiesco wrist pin bearings, sbt crank from JM
New Boyesen intake, dual stage reeds, and 46 mikuni carbs
Thrust billet head 190psi
Torrent 148 pump
Thrust ez pull Trim
New Driveshaft
New midshaft
New midshaft housing and oem bearings/seals
New ATP Total loss
Carbon and titanium skiworx adjustable pole
Titanium pole bolt
Thrust steering
Blowsion fat bars
Thrust finger throttle
Prok Flame arrestors
Tnt exhaust pfp waterbox: Flow control valves/sprayer, filter, etc
2 antigravity lithium batteries. One is new still in the box.
x-scream scupper
rule bilge
Worx intake grate
Waveraider motor mounts
Kart tank
2007 SJ steering cable
New thottle cable
New HD trim cable
Extra set of new foot holds
And everything else you need
Comes with title and current registration
12k
Video of it in action; friends first time riding an a/m hull. This is when it had a 144 pump and bpipe.
Some old pics as it is currently buried under old baby stuff in the garage. Pics show an rrp pole, but it has a skiworx carbon pole now.
Full sheet of s-glass on each side, bottom and nose. (Wont crack when practicing your rolls) Engine mounts reinforced with 12oz glass, firewall sealed and reinforced with 4-oz glass.
Closed cell foam:
30mm plush hydro padding * pic also shows old pump/trim setup.
Torrent 148 pump
Thrust ez pull Trim
New Driveshaft
New midshaft
New ATP Total loss
Titanium pole bolt
Thrust steering
Blowsion fat bars
x-scream scupper
rule bilge
Worx intake grate
Kart tank
New thottle cable
New HD trim cable
12k
Closed cell foam:
