The Penguin
triple secret probation
- down by the river
61X top and bottom (no porting)
lightened flywheel
CDI with rev limiter disabled
riva pipe
can't rememeber jet sizes right now
95 gm spring
probably 1.5 n/s
I seem to have a bogging problem off idle.
when I'm idling or just off-idle riding around and go to grab a handful of throttle - I'm getting a bog.
If I'm riding around about mid-speed and punch it - there seems to be no issue.
My low speed adjuster is out about 1 to 1.25 turns out. should I turn in the low speed screw a bit more - or try going to a smaller jet size?
lightened flywheel
riva pipe
95 gm spring
probably 1.5 n/s
