bolt to pull 750sx flywheel
its a 18mm X 1.5 I have found you can use a spark plug thread chaser to remove the flywheel. It is like 4 bucks at almost any auto part store, usually has 18mm on one end and 14mm on the other end.
Waternut
Customizing addict
Macon, GA
Good luck to you. Use penetrating oil on that flywheel if you haven't already. Heat helps too... I ended up destroying my stock flywheel trying to get it off but oh well.
tor*p*do
Squarenose FTW
NW NC
OK so I got a plug chaser screwed in
it wont tighten any more or back out and flywheel is still on . . . . :thinking:
any other great ideas?
I guess tomorrow I pull the fuel tank and try to get a socket on the chaser
WFO Speedracer
Alabama
Yeah don't believe everything you read here,some ideas are just bad,you have just experienced one of those bad ideas.
i didnt think the chaser was a good idea. when i did mine, i used a bolt, tightened down as much as i could and then used a hammer, on the bolt head, tighten down some more and hammered some more. i didnt use any heat but if it starts to go where you think its stripping the threads, then i would apply some heat and then hammer some more. you need to give it a good solid whack but be carefull coz it might just fly off.
I discovered the thread chaser a while back when I was trying to find a bolt that would work. I just heated the flywheel, then screwed that chaser in and popped it with a breaker bar and the flywheel fell right off. I actually ended up using it several times with no trouble at all. I really wish the 650 flywheels were like that, so I wouldn't need to use a damn puller every time I need to get the flywheel off my X2. Guess I should have just left 750 electronics in there if I wanted that though.
BruceSki
Formerly Motoman25
Long Island
a buddy of mine pulled my 750 flywheel off...
he had a homeade tool that was a cut end of a 440 or 550 crank welded to a nut
jam it in with the impact and it popped right off...
i can ask him exactly what the tool was
tor*p*do
Squarenose FTW
NW NC
the only "tool" I have found is a
750/800 - SPECIAL 18mm X 1.5 RIGHT HAND BOLT MP#18 $8.55
at JetWorld
Is that it?
i dont know if thats the size but when i bought mine, i went down to a specialty bolt shop and picked on up for about 5 bucks or less. cant remember. see if you have any specialty bolt shops around, might be able to pick it up vice waiting for it in the mail.
Waternut
Customizing addict
Macon, GA
at JetWorld
Is that it?
That's basically the same thing as the thread chaser....only the metal isn't as strong. I stripped one of those bolts inside my flywheel.
tor*p*do
Squarenose FTW
NW NC
got a bigger wrench and got out the thread chaser
soaking in PB Blaster all day probably helped too!
Now to find a good flywheel puller tool . .. . ..
tor*p*do
Squarenose FTW
NW NC
maybe this would do it?
This puller works on all Kawasaki 750-800cc flywheels.
http://www.watcon.com/Catalog_Pages/Kaw_SXR_Flywheel_Puller.htm
time to call Randy at Watcon?
tor*p*do
Squarenose FTW
NW NC
no hurry now, stator not yet back from JSS and I need to order about half a dozen misc parts.
I just want to order them all from one vendor, which is proving difficult
emailed Randy my needs list:biggthumpup:
tor*p*do
Squarenose FTW
NW NC
also upon closer examination
the interrupted threads on the thread chaser
did not play well with the
interrupted threads for the keyway on the flywheel
:soapbox:
