With the obvious answer you want them perfectly matched. What is the best way to confirm you have everything 100% matched?
My cylinder exhaust port is raised like almost 2mm, so I had a 2mm step down in the roof of the exhaust port as my manifold was not port matched and raised 2mm. I first port matched the gasket to the cylinder then transferred it to the manifold.
Then With the head removed and gasket and manifold temporarily mock assembled I could reach into the exhaust port via the cylinder and confirm my port match
I also bored the head pipe to 50mm and bored the manifold to 50mm, blended the 50mm into the runners and removed casting slag within the manifold runners and polished the ports.
Did I like the gain on my +8mm non PV 865 Lamey ?
No, all it did was soften the low end hit, made it smoother/softer, may have had a gain in mid range but all I noticed was less hit off the bottom. The smaller port seemed to lend itselft to low end.
May work better for bigger PV motors though
